Power cut and not working
Not working. Power cut
Is dit een goede vraag?
Like @rodolfomeave, I'm not familiar with your particular vacuum, but I had the same issue with a Harbor Freight shop vac.
By testing the power going to the fan motor, I finally isolated it to a failed thermal fuse on one of the motor leads. These are designed to blow when the temperature exceeds a particular limit, but I have no reason to think mine was anywhere near that range when it blew. Anyway, replacing the fuse got the vacuum up and running again and I haven't had an issue with it since. Here's the part I purchased; yours will probably look similar, although you'll need to use the markings on it to determine what value to use for a replacement.
Good luck, and be sure to come back and let us know what you find!
Was dit antwoord nuttig?
I do not have a Henry Vacuum, but if you are still having power issues there are some troubleshooting checks that you can do:
Hopefully this helps!
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 43
Altijd: 196
