Ga door naar hoofdinhoud
A2115 / 2020 / Processors van 3,1 GHz 6-core i5 tot 3,8 GHz 8-core i7. Uitgebracht op 4 augustus 2020.
SDD ribbon cable replacement
I have a bare 820-01779-A logic board and am trying to identify a small ribbon cable connector on the screen-facing side of the board. There are no SATA connectors on the heatsink side as seen on 2019 boards. Can anyone identify what this ribbon connector is and whether it has any relation to SATA storage?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The 2020 model dropped the SATA port and even the Blade SSD! This series has soldered on Flash chips on the logic board on the base models and only on the high end give you access to more SSD storage via a custom flash (NAND) module. I haven seen this model personally, I suspect it's the same as the iMac Pro 27" 2020 iMac specs
Bottom line you can't upgrade or expand this systems storage internally.
Was dit antwoord nuttig?
Voeg je antwoord toe
pdstreeter@hotmail.co.uk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 66
