Ga door naar hoofdinhoud
Reparatiehandleidingen en informatie over het demonteren van de 14-inch MacBook Pro die in oktober 2021 werd uitgebracht, uitgerust met door Apple ontworpen M1 Pro- en M1 Max-SoC's. Model A2442.
Can I replace or fix the microphone?
The microphone on my M1 Macbook Pro is very muffled.
After some investigation, I'm fairly sure the problem is a blocked grille. But it's hard to identify which (if any) of the hundreds of dimples on the left-hand side are actual holes and therefore need cleaning. Is there any information on this?
Is dit een goede vraag?
Score 1
1 Opmerking
Faced with exactly the same problem. I suffered for a long time. In the end, I solved the problem using an old toothbrush and isopropyl alcohol. I soaked the brush in alcohol and massaged the mesh for a few minutes. The computer was turned off. I waited 10 minutes and turned it on. The problem has been resolved
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I poked around with a pin in the 'holes' on the left hands side, and found some holes that were deeper than the normal divots, about 5 rows in from the right hand side, near the tab and caps lock key. Poking the pin into these fixed the problem.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Ben zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 30
Altijd: 240
