Ga door naar hoofdinhoud
Model A1136 / 30, 60, of 80 GB harde schijf / zwarte of witte plastic voorkant
iPod won't charge
I bought a used Ipod Classic 5 about two months ago. The seller put a new battery in as well. I have been using it fine for about two months now. Charging via wall and/or computer worked fine. I haven't used it for about two weeks now and the last time I used it I did until the battery was completely drained.
I went to charge it on my wall outlet now and it wouldn't show any signs of life.
I waited a good 2 hours and still nothing happened.
Whenever I tried turning it on, it would just show the apple logo for a brief second and then shut off again.
Something weird to note is that after nothing happening via wall charge I tried charging it on my computer and when I plugged it in I got a windows notification for a USB power surge, telling me to immediately remove the device from USB because it was drawing too much power.
What could be happening? And how do I fix it?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Replace the battery. The battery the seller replaced it with is probably a low quality cheap one.
Was dit antwoord nuttig?
1 Opmerking:
It looks like you can get the full Fix Kit from iFixit for $19 USD
door
Try use Firewire if you can, if it shoots into life, which it should as it gives much more power and it lets iPods with even a basically dead battery to turn on, it is probably the battery that is the issue as it may be a low-quallity one.
iPod 5th Generation (Video) Batterijvervanging
Voeg je antwoord toe
Pazulay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 126
