Ga door naar hoofdinhoud
Reparatie-informatie voor de Dell Latitude 6000-laptopserie.
Charging port failure when charging
Why is my laptop switch off the power adapter once I connect to the charging port?
I have even tried other adapter and the same still happen
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
If your laptop switches off the power adapter as soon as you connect it to the charging port, the issue is often related to the charging port, battery, or motherboard power circuit. First, inspect the charging port for dust, bent pins, or debris and clean it gently with compressed air. A damaged DC jack can also cause a short, forcing the adapter to shut off for safety. Next, try removing the battery (if removable) and power the laptop directly with the adapter to see if the battery is faulty. You should also check the adapter cable for damage. If the problem persists, the motherboard charging circuit may require professional repair.
Was dit antwoord nuttig?
Voeg je antwoord toe
stephen mutuku zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 136
