Ga door naar hoofdinhoud
Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
Touch ID pairing - Self Service Repair
I am a little confused by the Self-Service Repairs from Apple, and what is and isn't possible.
When I attach a second hand screen (genuine Apple) it gives me the option to finish the repair and it calibrates accordingly.
When I try a second hand Touch ID (genuine Apple) it fails to recognise it as being a genuine part.
My questions are - is it possible to calibrate a Touch ID now through Apple's program? And if so, would I need to buy a new button through the Self-Service Repair from Apple?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
I was going through the self repair program information, and every indication is that the Repair Assistant seems to be able to recalibrate a Touch ID board, at least one purchased from Apple. They don't differentiate that repair from any other one they talk about, so I don't know if there is some restriction on only working on one you bought directly from Apple vs. a used part, but it does specifically mention repairing Touch ID on the M1 MacBook Air.
Mac Laptops Troubleshooting Input/Output Issues - Apple Support
Here's the part they're selling; I assume that's what you're replacing.
Self Service Repair Store
They actually show the repair assistant popping up for a new Touch ID board on their guide to invoking it.
Use Repair Assistant to finish a Mac repair - Apple Support
At this point we're really only guessing; only Apple can authoritatively answer the question of why you can't seem to calibrate a used Touch ID board since they show that process in operation. @flannelist Alisha, do you have any thoughts on this?
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Only a new virgin TouchID button and as far as I know only installed by Apple and the data on the drive is lost
door
You are mixing different aspects of Apples Security
Parts Serialization - To kill off knock off parts (not a real issue) - Using the re-serialization (calibration tool) which only works with real Apple parts.
TouchID - Systems data security - The TouchID is married to the its mated logic board and no other!
I just tested this, because I found conflicting information. A Macbook Air M4 with Find My disabled. I installed a new logic board from selfservice and left the old TouchID in place. It doesn't work, it won't pair.
Voeg je antwoord toe
alasdair Sim zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 74
Altijd: 284
