Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
580 Vragen Bekijk alle
Swapping harddrive for SSD in MacBook Pro 15 inch (2012).
Hey,
I am looking to swap the harddrive of a new 2012 MacBook pro 15 inch with an SSD and then replace the optical bay with the original
I was wondering if the process is exactly the same as previous models. I have looked at the tear down but wanted to make sure
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Here's an article by OWC and bench results on the 15" standard: http://blog.macsales.com/14263-owc-ssds-...
Was dit antwoord nuttig?
Score 2
I did this yesterday. I installed a Samsung 512GB SSD. The guide for the late 2011 model did match perfectly:
MacBook Pro 15" Unibody eind 2011 Vervanging van de harde schijf
And use this one for cloning the harddisk:
Hoe installeer je macOS High Sierra?
Mac OS X Afbeelding
Handleiding
Moeilijkheid:
Eenvoudig
1 - 3 hours
MacBook Pro 15" Unibody Late 2011 Harde schijf Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
25 - 40 minutes
hi,
I am planning to replace my existing HD with a new SSD. Im on OS X Lion 10.7.4
I need to clone my HD on to my SSD. Can I not do this using my latest Time Machine Back up?
wouldnt the TM back up install the OS plus all my applications and files etc ( basically bring it back to the current state including preferences)?
Is this what time machine is for?
thanks
1 Opmerking:
Akshay,
If you opt to install by using a TM backup, all your data, applications and preferences. The only thing to account for is that the SSD needs to have the more space that what your TM backup uses.
door
Voeg je antwoord toe
jchu1990 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 38,358
