Ga door naar hoofdinhoud
My vibration mode not working
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Check Vibration Settings
  • Go to Settings
  • Tap Sounds and vibration
  • Make sure Vibrate while ringing is turned ON
  • Tap Vibration intensity and increase it
Check Sound Mode
  • Press the Volume Down button
  • Make sure the phone is in Vibrate or Sound mode (not completely muted with vibration off)
Test Vibration Manually
  • Go to Settings > Sounds and vibration > Vibration intensity
  • Adjust the slider and see if the phone vibrates
If there is no vibration at all, continue below.
Restart Your Phone
Sometimes a simple restart fixes minor software issues.
Check Accessibility Settings
  • Go to Settings > Accessibility > Interaction and dexterity
  • Make sure no setting is disabling vibration
Boot in Safe Mode
This checks if any third-party app is causing the problem.
  • Press and hold Power button
  • Tap and hold Power off
  • Select Safe Mode
If vibration works in Safe Mode, an installed app is likely causing the issue.
Was dit antwoord nuttig?
1 Opmerking:
Not working I think vibration motor not working
door
Voeg je antwoord toe
Deb Mandal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 34
Altijd: 118
