Ga door naar hoofdinhoud
Why is the screen glitched?
Every time i turn it on the screen is covered in fuzzy looking glitches
Is dit een goede vraag?
1 Opmerking:
Have you tried plugging in an external monitor? That will tell you if it's a memory/GPU issue or a screen problem.
door
Voeg een opmerking toe
1 Antwoord
A fuzzy, glitchy screen on startup is usually caused by a hardware or connection issue. Common causes include a loose or damaged display cable (especially in laptops), a failing graphics card, outdated or corrupted display drivers, or a dying screen panel. First, try connecting your device to an external monitor. If the external display looks normal, the issue is likely the screen or its cable. If the glitches appear on both displays, the GPU or drivers may be the problem. You can also try updating graphics drivers or booting into safe mode. Persistent glitches often indicate hardware failure requiring repair.
Was dit antwoord nuttig?
Voeg je antwoord toe
Smurf_ zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 112
