Ga door naar hoofdinhoud
Informatie over reparatie en demontage van de Samsung S22 Ultra-smartphone, uitgebracht in februari 2022.
Phone not connect to Network
I can't connect to my operator network, there is not signal, I'm able to do call with wifi, but out in the street I don't have connection or data. Is any part that I can replace?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
If Wi-Fi calling works but you have no signal outside, the issue is usually SIM, settings, or antenna — not something you can easily replace yourself.
Try this first:
Turn Airplane mode ON for 30 seconds, then OFF.
Restart the phone.
Remove and reinsert the SIM card (clean it gently).
Test your SIM in another phone. If it also has no signal, contact your carrier for a SIM replacement.
Reset Network Settings (this won’t delete photos/apps).
If the SIM works in another phone, your device may have a faulty antenna module or baseband issue. That requires professional repair — internal antenna parts aren’t easy DIY fixes.
Was dit antwoord nuttig?
WiFi calling worked but zero signal outside, and it turned out not to be a “replaceable part.” First check SIM (try it in another phone) and reset network settings; if that doesn’t fix it, it’s usually a carrier issue or a damaged antenna/modem, which isn’t really worth repairing. I’d rule out SIM/carrier before thinking hardware.
Voeg je antwoord toe
Holman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 187
