Ga door naar hoofdinhoud
De PS5-console, uitgebracht in november 2020, beschikt over aanzienlijk verbeterde graphics en een innovatieve nieuwe Dualsense-controller. Het futuristische zwart-witte kleurenschema wijkt opvallend af van de PlayStation-ontwerpen uit het verleden.
Pss5 not recognizing discs
Every time I turn on my PS5, the disc drive runs but says it does not recognize the disc. I have already tried replacing the disc driver laser, KEM-497aaa. The model is CFI-1115a.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
Usually it is the laser, but it could be way more (drive board, other components on there, etc.).
I recommend to try with a new drive, and see what happens.
Note: Always transfer your original board (from the OLD drive to the >>> New drive)!!!
Can you let us know how that goes?
Thanks!
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
I have already tried replacing the part 3 times that’s why I’m looking for any other ideas to try and help
door
Hi! Did you replaced the whole drive 3 times? Or just the laser? Thank you!
door
@dan0 I replace the whole drive!
door
okay, then I'm afraid it's related to either the motherboard or the PCB. Is there a way for you to test them (and do you have soldering experience)? If the PCB is broken, it would be difficult to fix as you cannot marry a new PCB to the motherboard. Otherwise I recommend to check with a local repair shop. Sorry.
door
Well, you can't re-pair the boards unless you happen to be Sony and have all of their proprietary pairing software. You might also try moving the component that actually pairs the drive PCB to the motherboard, but last I checked, that's not easy to do and requires microsoldering to pull off (But hey, try it if you want!). You could also try to figure out if there's a specific component on the board that's being problematic and replace it.
door
Voeg je antwoord toe
MoJama zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 26
Altijd: 86
