Ga door naar hoofdinhoud
Bijgewerkte versie van de MacBook Retina uit 2016. Model A1534, EMC 3099. Beschikt nu over snellere Kaby Lake-processors tot 1,4 GHz Core i7 met Turbo Boost tot 3,6 GHz en een tot 50 procent snellere SSD, en ondersteunt tot twee keer zoveel geheugen.
removing back cover to replace battery
My Macbook air only has 8 screws - all of the videos show 10 screws.
I have removed all of the screws and go to remove the back and it does not lift off so nice and easy - looks like there is a catch about halfway on both right and left side. Do I force it open?
Update (01/22/26)
Okay - so first of all it was not a Macbook Air - it was a Macbook. I took a picture of the writing on the back and was able to zoom in and find the model and EMC number.
Once you get the screws out there are 2 clips - one on each side that are a bit stubborn...but you get them unclipped and you got it.
I also had the wrong battery....so wait for now
Thanks for the feedback
Pat
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hello, can you double check the model of MacBook that you have? Some of the older models pre 2020 have 10 screws. Try to find a model number/year if you can.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Pbmacsodak zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 19
Altijd: 177
