Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Galaxy A04s is een betaalbare smartphone met een groot scherm en een redelijke batterijduur. Hij biedt basisfuncties en -mogelijkheden voor dagelijks gebruik.
How to change a broken screen?
Is dit een goede vraag?
Score 3
4 opmerkingen
First ill have to remove the screws and unplug the battery and screw out the inor screws before trying to remove the screen.
door Deel
depends on your phone model, and which tools you have in home ?
door Deel
No, i dont have any tools..
door Deel
How to replace screen of samsung a04
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi Carl,
Sorry the other answers aren't much help to you; I'll see if my answer is a little more useful.
iFixit doesn't have a guide to replacing the screen on your phone, but fortunately the French site SOSav has just what you need. As you might guess, the site is in French, but if you use it with a browser like Chrome that does translation, it will be quite useful and their guides are well written.
Réparation Bloc écran Galaxy A04s - Guide gratuit - SOSav.fr
Your phone is like most Samsung and many other Android phones in that there are two ways to replace the screen, The recommended way is to purchase the screen already mounted on the midframe, then replacement consists of essentially gutting your old phone and moving everything inside to the new midframe. It may sound daunting, but Samsung actually makes it pretty straight-forward. This gives you a brand new midframe and screen, and saves you the difficulty of gluing the new screen onto the frame. That's the method shown in the guide I linked to.
The other way to do it is to only remove enough parts to access the display connector, then you have to separate the screen from the midframe. Once that's done, you clean all the old adhesive from the frame, run a bead of glue all around the edge of the frame, then glue the new screen on. It will need to dry for some time, and it should either be weighted down or bound with rubber bands until it does. That process requires an entirely different guide. I wasn't able to locate a written guide to that repair for you, but this YouTube video shows you the process.
How to replace the screen on your Samsung Galaxy A04s: Easy steps - Asha Mobile - YouTube
The price difference between buying the screen alone vs. the screen+frame assembly is usually only a few dollars, and you can easily make up that difference by having to buy a tube of glue, so price shouldn't be a significant factor in deciding which method you want to use.
After going through the first guide, here's a list of the tools they use.
You can support iFixit's repair efforts by buying most of the tools you need from them, or they are readily available on major sites like Amazon, eBay and AliExpress. Those three sites should also carry replacement screens, with or without the frame already attached.
Good luck and let us know how it all turns out for you!
A tougher take on a favorite multitool. Safely poke and pry with this tough, firm, and antistatic tool for electronic repair. 5” carbon fiber tool essential for smartphone or tablet disassembly. Afbeelding
Product
Spudger
$3.99
Precision fixed blade screwdriver engineered by iFixit. Afbeelding
Product
Phillips #00 Screwdriver
$5.49
Three slim tweezers for holding and manipulating small and delicate components. Blunt, pointed, and angled versions. Ergonomically shaped and ESD-safe. Includes a sturdy storage pouch. For electronics and other tasks where keeping a good grip is important. Afbeelding
Product
Precision Tweezers Set
$11.95
Handy tool for opening devices, spreading thermal paste, and scraping. Same as Apple Tool Part# 922-7172 Afbeelding
Product
Plastic Cards
$2.99
Thin prying tool for opening electronic devices. Opening picks are essential to open any iPad, tablet, or smartphone sealed with adhesive. Afbeelding
Product
iFixit Opening Picks (Set of 6)
$4.95
Springy steel blade features a smart tip design and a handle with a great no-slip grip. Effortlessly pops open iPod, iPad, iPhone and many other tablets, smartphones, and devices. Afbeelding
Product
iSesamo Opening Tool
$10.99
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries. Afbeelding
Product
iOpener
$24.95
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Carl Angham zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 60
Altijd: 406
