Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
error 13 iPhone 3GS
hi i keep getting error 13 when i try to restore my phone ,can any one help
Is dit een goede vraag?
Score -1
1 Opmerking
Is your iPhone jailbroken? A jailbreak can sometimes make it much harder to restore.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If you tried a different cable and usb port and still have this error try this.
Step 1. close out itunes and disconnect your phone
Step 2. turn your phone completely off
Step 3. relaunch itunes
Step 4. plug in the usb end into your computer, but do not connect your iPhone yet
Step 5: This is the somewhat tricky part....hold down the round circle home button while you plug in your iPhone.
This is should bypass any software currently on the phone that is corrupt and do a fresh install. Of course you probably already know that all information will be lost from your phone - so hopefully you backed up before the crash.
Was dit antwoord nuttig?
Score 1
And if Mayer's solution fails, you may need to put it into DFU mode. You can do that by following these steps:
  1. Plug your iPhone into your computer
  2. Turn your iPhone off.
  3. Hold down the home button and power button for exactly 10 seconds.
  4. Release the power button but keep holding the home button.
  5. Hold in the home button for another 10-20 seconds. If you are using Windows, you'll hear the device connection sound. If you are using a Mac, open System Profiler and look at the USB hub. You may need to refresh the tree, but you should see a device labled as "DFU Device" or something along those lines.
Cheers!
Voeg je antwoord toe
dave zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 4,855
