Ga door naar hoofdinhoud
De Airpods Pro 2 met een USB-C-oplaadbehuizing heeft verbeterde stofbescherming, snellere oplaadmogelijkheden en de mogelijkheid om Lossless Audio te gebruiken met Apple Vision Pro. Hij beschikt ook over Adaptieve audio, Gespreksdetectie en Persoonlijk volume.
Left side is not working
My airpod got on water and i clean and drain it and it work for a weak but now the left side is not working what shaĺl i do
Is dit een goede vraag?
Score 1
1 Opmerking
It fell down only
door
Voeg een opmerking toe
7 Antwoorden
Filteren op:
Het nuttigste antwoord
Unfortunately, there is not much that you can do, AirPods are generally impossible to open and repair without causing damage to the plastic case.
Water damage happens when corrosion from minerals from your water make contact with the circuit boards of your earphones. You may have to throw away your left earphone since the damage has already happened. Sorry for your situation :(
Was dit antwoord nuttig?
Score 2
Well I will suggest you to checkout the following video: https://www.youtube.com/watch?v=Z77mEmP1...
Some time only I used both AirPods but most of time I used only one side AirPods. One day when I used both AirPods that time I realised one of them AirPods it’s not working.
I have the same problem only my left ear pod is not working also I didn't drop in water
It was kept on a computer desk and will use it once a week, I tried cleaning the ends and charge ends but nothing works, the right side works and charges asusual
No
It fell down only
It fell down
Lift side no working
Voeg je antwoord toe
saba beyene zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 75
Altijd: 640
