Ga door naar hoofdinhoud
Reparatie- en demontage-informatie voor de Pixel 6-smartphone van Google, uitgebracht in oktober 2021. Te identificeren aan modelnummer GB7N6 en G9S9B16.
New LCD Screen (with frame) - can't install
I purchased a new LCD screen for my pixel 6. I got the one advertised as 'with frame'. I realize now that the screen that i took off the phone came out without the said frame. What is the approach I should take - can I remove the frame that is within the phone along the sides or do i remove the frame from the new screen (which doesn't appear easy). What approach is best/possible? If i can remove the old frame from the phone does the new screen with the frame just click in at that point?
Is dit een goede vraag?
1 Opmerking
I had the same issue. I play games on my phone which makes it heat up. After years of heating up too much, the adhesive holding the screen to the interior frame wore away. And then a few drops of water splashed onto the exposed edges and took out the screen immediately. The replacement I ordered had the frame attached. I removed the old frame. New screen worked perfectly. But, when trying to get it secured, one part of the frame wouldn't pop into place. Having zero experience with screen replacement, I just tried pressing harder on that point of resistance and ultimately (obviously) ended up destroying a brand new amoled display. Nowkim scared of getting a 2nd replacement screen. Is there some sort of trick to it?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
With all due respect to @uchetil, I think Juan Garcia has it wrong. Many Android phones like Samsung have two different ways to replace the screen; one, you can buy just the screen by itself, detach it from the phone's frame, then reglue the replacement on. The other way to do it is to buy the screen already attached to the phone frame and basically gut the old phone, moving all of the interior components to the new screen+frame assembly.
So it's understandable that when you're talking about the frame, they thought it was like a Samsung. It's not; Pixel phone screens are not available already attached to the phone frame, and you can't access the interior parts without removing the screen.
Anyway, the frame you're talking about is the mounting frame for the screen that isn't supposed to come off the screen. What's happened is that instead of getting your opening pick between the frame and the phone, you ended up inserting it between the screen and its frame. If you look at the Pixel 5 Screen Replacement Guide, on Step 2 it specifically cautions about where to insert your pick, which is exactly where you went wrong. Here's the picture and text from that step.
Afbeelding
  • Screen seam (red): This seam separates the screen from the rest of the phone. Do not pry at this seam.
  • Bezel seam (orange): This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
The fix for this is to simply repeat the opening procedure on the frame that's left on the phone. And no, you should not attempt to remove the frame from the new screen; you'll almost certainly damage the OLED display if you try. Since you can't use a suction cup, get it started by prying up from the inside until you can get an opening pick in, the proceed with the normal slicing of adhesive process. Once you have the frame off, you can then continue with the normal steps of the guide. Be sure to clean off the old adhesive from the phone and be careful installing the precut adhesive; it's not very forgiving so you'll need to get it place on there correctly the first time (I usually buy a spare just in case).
Good luck, and let us know how it all turns out!
Was dit antwoord nuttig?
Score 2
@foneguy
The guide here uses the screen without the frame, so until the end, you need to follow the procedure this fellow shows in his VIDEO, I'd consider looking at the IFIXIT guide for what to do as far as reprogramming the fingerprint scanner etc, that link is HERE.
Hopefully this will be all you need. And, although the cost is a little higher, your framed screen is a less risky repair to do. Just be careful, don't lose the screws, Have fun! Soooo... You pick which way to go, look at both, but I'd remove the frame from the phone as less risky than trying to get the new screen out of the frame... or, you could try sending it back and get the one with no frame, and perhaps a small rebate, since you already have the screen off.
Good Luck.
2 opmerkingen:
This guide shows the screen with the frame on the screen. my screen came out without the frame, however, the new screen has the frame on it (as is illustrated in the picture shown above). In the end i did manage to pull the old frame out of the phone so i think i am away to the races now.
door
@Jerry Wheeler is correct, it seems, good luck. I"m gonna re-check the video and see what's up there though... And good luck, again
(Thanks, Jerry)
door
Voeg je antwoord toe
foneguy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 40
Altijd: 309
