Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Keyboard light stopped working
I need to know how to get my keyboards key lights to start working again. I believe its in the physical functionality itself as ive checked all software and settings.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi!
This may differ from one Lenovo model to another.
In my case, Keyboard backlight can be changed in the Lenovo Vantage application. In Device Settings > Input > Keyboard backlight brightness. There I can change between low, high and off in terms of brightness level.
The hotkey combination in my case is FN + space to change between the different brightness modes.
Hope this helps,
Cheers
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you for responding. However, I received more information on what happened when the keyboard backlight stopped working. One of my teen aged boys admitted to dropping something heavy on the keyboard. I suspect the problem is more of a physical nature at this point. Thank you for your response, though
door
Voeg je antwoord toe
DannyBoy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 39
Altijd: 318
