Ga door naar hoofdinhoud
Repair information for LG ovens, ranges, and stoves.
help with lg orifice sizes
Trying to convert LG stove to LP..... I have many spare orifices that might/should work. LG identifies the orifices by letter and location....EX: for LP, Broiler is "D".
Anyone aware of a list or chart that shows the actual size of LG orifices with the corresponding location letter? Thanks
Is dit een goede vraag?
2 opmerkingen
Hi @geezo
What is the model number of the stove?
door
LG Stove model lrg3095sw / 00 THANKS JAYEFF!!!!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @geezo
Here's the service manual
On p.43 of 79 (Sect 5-2 in manual) there a table showing the LP gas orifice code numbers and below that the burner layout diagram. (On p.44 it shows the Natural Gas orifice code numbers)
The complete conversion procedure starts on p.42.
Unfortunately it doesn't specify the actual size of the LP orifices, just their code number
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks again Jayeff. The doc will be extremely helpful! It shows the btu's for each orifice code, which should/maybe? indicate orifice diameter. Thanks again!!
door
Voeg je antwoord toe
Geezo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 39
Altijd: 39
