Ga door naar hoofdinhoud
Reparatiehandleidingen en demontage-informatie voor de 14-inch MacBook Pro die in januari 2023 is uitgebracht, voorzien van door Apple ontworpen M2 Pro en M2 Max SoC's.
Battery replaced not working
I have a a2779 MacBook Pro , I started getting a service battery warning last week and when I run out of power the mag safe started flashing orange and did not charge , I ordered a replacement off I fix it for the model, I fitted it this morning and when I plug the mag safe in now with the new battery installed I get no light and it does seem to charge, I tried to charge via usb c left it charging for 1 hour but nothing, can anyone help? Thanks in advance
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
A common issue is forgetting to set the ZIF latch from the Battery board or the cable./connector is damaged. Review Step 7 ~ 9 MacBook Pro 14" Early 2023 Batterij vervangen here is the referee making sure the latch is not set, sliding in squarely the ribbon cable and carefully setting the latch so it's grabbed. Also check the battery side connection as well.
If the cable is damaged you'll need a replacement MacBook Pro 14" BMU Flex Cable - Apple P/N 923-08652
Was dit antwoord nuttig?
Voeg je antwoord toe
Joedee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 162
