Why does my console not turn on
My console turns on but doesn't display anything on the monitor/ TV there's beeping I try to use safe mode but it doesn't work I cleaned out the dust already
Is dit een goede vraag?
1 Opmerking:
Hi!
So, did you tried both the HDMI and AV cables?
If you try to use it with HDMI now, I would get the AV cable and try that one as well.
It's most likely motherboard related, but let see if you can get it to show something at all.
You can also try a new HDMI cable on another TV to see if that works.
Please let us know if this fixed it or not, otherwise you might want to check the motherboard.
door
Voeg een opmerking toe
