How should I fix the Xbox One system error E100?
Hey, guys, my Xbox One device encountered an error after an upgrade, and then I found that the 1t mechanical hard drive inside was damaged. I replaced a new 500G solid-state drive in, but after turning it on, the error code E100 0000070D 80070002 appeared I tried several troubleshooting methods. I used a USB flash drive to download the offline system (OSU1) for manual update. When the update progress bar reached 3/1 (download completed), the error E101 90060007 8B05000F was displayed and the update could not continue.
Also, I refer to the Firmware installeren op Xbox One S this post using a script to install the system directly to the hard On the disk, the process went smoothly, but after reinstalling the hard drive back into the machine, nothing happened and the E100 error still occurred.
Are there any other ways? I need some advice and help. Thank you
Is dit een goede vraag?
