Lens wont fully close!
The lens will not close fully, it just pops back out when I try to push it closed. I'm not sure if I need to add other information, but let me know please & thank you!
Is dit een goede vraag?
Score 1
2 opmerkingen:
I'm having this problem as well. I've removed the case but there's still no obvious way to get the lens to stay down and shut/closed.
door Deel
I've further taken apart the camera and unfortunately found the problem: two little plastic pieces that keep the lens fully closed are broken. This may have happened when the lens was pulled open instead of using the button.
I don't know how or if it can be fixed. Yet.
door Deel
Voeg een opmerking toe
