Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De op 13 oktober 2020 aangekondigde iPhone 12 mini is een kleinere versie van de iPhone 12 van Apple. Het toestel beschikt over een 5,4-inch oled-display, een A14 Bionic-processor en twee camera's achteraan.
which speaker needs replacement
I use my (corded) ear phones or turn on speaker to hear a phone conversation. Which speaker needs replacing?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
If you can't hear phone conversations unless those methods are employed, you need to replace the "Top speaker" or "Receiver speaker" (it's called either). It's part of the sensor assembly on the back of the display. Some of those sensors are tied to Face ID function so you'll either need to solder a new speaker into the flex cable, or use Apple approved methods of replacing to retain Face ID
Replace an earpiece speaker or sensor assembly compatible with the iPhone 12 mini models A2176, A2398, A2399, A2400. Afbeelding
Product
iPhone 12 mini Earpiece Speaker and Sensor Assembly
$23.99
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
I am replacing the battery and screen as a first timer. Are you saying I can replace without soldering if im willing to let go of face recognition? I will absolutely never use that tech.
door Deel
Also there is no mention of soldering in the directions to replace "sensor assembly"
door Deel
@maurak13 If you replace the whole assembly then no, but you will lose Face ID. Otherwise you can transplant the speaker from another flex cable, but those are soldered into the sensor assembly.
In comparison Apple would probably have you replace the whole display assembly.
door Deel
@maurak13 As an example, here is a guide showing how to replace the earpiece speaker without losing Face ID. This is for an iPhone X, but the last step of removing the speaker will be similar to what it would be on your phone.
iPhone X Earpiece Speaker Replacement Without Losing Face ID - iFixit Repair Guide
Just follow the iPhone 12 Mini earpiece speaker assembly replacement guide up to Step 27, then switch over to Step 29 of the iPhone X guide. The spots you need to unsolder will be in a slightly different place, but the procedure is basically the same.
Score 1
Voeg je antwoord toe
maurak13 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 40
Altijd: 513
