Ga door naar hoofdinhoud
Support and repair information for laptops made by Samsung.
Why my Samsung laptop goes off suddenly after heating? Any solution?
My Samsung laptop goes off suddenly when heating up. What must I do to solve this problem
Update (08/31/25)
MODEL: Samsung Notebook NP - R525 - JSO2RU
Is dit een goede vraag?
1 Opmerking
Can you give us the model info so we can help you. Click on the Samsung image to the right to find your system.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @isaackingsf9025
Is the fan in the laptop working OK?
It may be that it needs to be cleaned of any dust and also that the thermal paste on the CPU has dried out and needs to be refreshed.
Having a fan with restricted airflow and possibly dried thermal paste on the CPU may cause the laptop to turn off so as to protect the CPU from overheating and being damaged.
Here's a video that shows how to open the laptop and remove the fan so that if it needs cleaning, this can be done outside of the laptop. You can also see the CPU (once the heat sink has been removed with the fan) to check the condition of the thermal paste to see if it needs replacing.
Here's the ifixit Aanbrengen van koelpasta guide that may help.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Isaac Kingsford-Bansah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 59
