Ga door naar hoofdinhoud
Why is my poweradapter Overheating?
I Have battery issue my battery wotrks but my pc suddenly shut down when the battery is less than 50 percent can you help me
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Step 1: Generate Battery Health Report
  1. Press Win + X → choose Windows PowerShell (Admin) or Command Prompt (Admin).
  2. Type: powercfg /batteryreport
  3. Press Enter. It will save a file (usually in C:\Users\<YourName>\battery-report.html).
  4. Open it in your browser.
    • Look for:
      • Design Capacity vs Full Charge Capacity.
      • Cycle Count (how many charge cycles used).
👉 If Full Charge Capacity is much lower (like 50–60% of design), your battery is worn out → needs replacement.
Step 2: Try Battery Calibration
Sometimes the issue is calibration, not health.
  1. Fully charge to 100%.
  2. Use laptop until it completely shuts down.
  3. Plug in and charge back to 100% without interruption.
    This helps Windows re-learn the battery percentages.
Step 3: Consider Replacement
If calibration doesn’t fix it, and the report shows degraded health, you’ll need a new battery.
  • The HP 15-bs0xx uses HP MU06 or MU09 type batteries (depending on exact sub-model).
  • You can check your current battery label by removing it.
Adapter Overheating
This is also common with older HP laptops.
Causes:
  • Using a lower wattage charger (yours likely needs a 65W or 45W HP Smart AC adapter depending on CPU).
  • Dust or poor contact in the charging port.
  • A failing adapter.
Fixes:
  • Make sure you’re using the correct HP-branded adapter (check sticker on adapter for wattage).
  • Don’t place it on beds/carpets while charging → use hard surface.
  • If it still overheats, get a replacement adapter (generic ones often cause issues).
Was dit antwoord nuttig?
Voeg je antwoord toe
Muhammad Fahad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 240
