Ga door naar hoofdinhoud
Speed Queen makes noise during wash cycle
Washer makes metal to metal grinding sound during wash cycle. Happens with medium to full loads.
Is dit een goede vraag?
2 opmerkingen
Hi @cliff93935
What is the model number of the washer?
door
Thanks for responding. Model # of washer is AWN432SP113TW04.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @cliff93935
Not sure but it could be either the upper or lower bearing.
Here's a video that may (or may not) help to check if they're OK or not.
If the bearing is the problem, the part number for the bearings in your model is 28944RP (supplier examples only).
Here's the service manual for your model and also a parts list that may also help. If another part is the problem, locate the wanted part in the list and note the part number shown for it. Search online for the part number only, to find suppliers that suit you best.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Cliff zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 82
