Ga door naar hoofdinhoud
Reparatie-informatie voor de HP 600-laptopserie.
My laptop won't charge
I have two HP laptops. One of them won't charge using the same charger. If I charge the battery on the first one and place it in the second laptop work fine. I disassembled it and checked for the DC power jack, and it worked perfectly. Any ideas about what could be the problem?
Is dit een goede vraag?
4 opmerkingen
Have you tested that the battery of the non-charging laptop works? If not, try putting that battery in the laptop that won't charge and see if you get the same issue.
door
@havynkrentz battery works perfectly. I guess there's some problem in the motherboard. Everything works as it should, except it won't charge.
door
@anwar29099
What is the full model number of the laptop that doesn't charge?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @anwar29099
Here are the motherboard schematics that should help.
Go to p.8 and following the DCIN path from pin 1 of the DC-IN cable connector on the motherboard to see how far you get. Also check that the circuits connected to the other pins i.e. 3,4 &5 are also OK
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Anwar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 152
