Is it possible to replace the flimsy usb cable?
I see people modding their keyboards with threaded usb-c cables, I was wondering if it was possible, and how difficult it would be to do so.
Is dit een goede vraag?
Score 1
4 opmerkingen:
As long as the cable is data & charging USB-C cable, it should be fine, but maybe a charge-only cable won't work.
door Deel
I guess my deeper question is, is there a guide, that can be preferably made here or found elsewhere. I have the soldering kit, I just need to know what the appropriate cable would be that works. And what tools to use with case, as the cables I've seen are wider than the one that comes with the elgato.
door Deel
@samuelcabr82639 Doesn't look like there is a guide here, but you could embrace the spirit of iFixit, try it out, document your process, and create your first guide
door Deel
I use it for work so I'm not entirely keen on break a $150 machine.
door Deel
Voeg een opmerking toe
