De Volkswagen Beetle was een compacte auto die werd geproduceerd door de Duitse autofabrikant Volkswagen. Hij werd in 2011 geïntroduceerd als opvolger van de New Beetle.
Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
Could be a faulty oil pressure sensor or a problem with the wiring connected between it and the engine management control module, or worst case it's a faulty oil pump in the engine.
Best to get it checked out as you don't won't the engine to seize due to no oil lubricating it when it is running if it is the oil pump.
Hi @khotsochappie
What year is the vehicle?
have you checked the oil level on the engine oil dipstick to make sure that it is at the correct level?
door jayeff
Hi @jayeff
Thank you for responding.
I’ve checked the oil level and it’s on the correct level. Is there any other issue that could cause it
door Khotso Chappie
@khotsochappie
What year is the vehicle you never said?
door jayeff
I’ll do so thank you so much. It’s a 2014
door Khotso Chappie
