HP Envy lost WiFi and Bluetooth capabilities
My wife has an HP Envy 17t-cr000 laptop at home that she uses for personal and work purposes. It's several years old and running Windows 11 Home, Build 26100. She had been using it with the internet Monday evening and everything was working normally. It sat in hibernation when she was done, through the next day, into the evening when she got home and had some other work to do. She had no internet whatsoever and the Bluetooth connected mouse stopped working. The error message read: "You're connected using a virtual network adapter that we can't test."
The Wi-Fi was and is working fine, as I could access it on my desktop without problem. The normal options for her to select or add a network or connect Bluetooth were missing completely. The "Plane Mode" option was there, but grayed out. I looked up the error message online and performed the fixes I found, all to no avail. I reloaded all the network drivers as well, but nothing worked.
I contacted Microsoft tech support who walked me through some other procedures without success. They suspected it might have had something to do with the last Windows update, but that was loaded before the problem began, so there was a period under the latest update when everything was working fine. Unfortunately the restore point option had been disabled at some point in the past, so a rollback wasn't possible. However, I was able to do a Windows 11 re-installation just to try everything. This also failed to solve the issue.
I let the Microsoft tech know and they feel they had exhausted all the system fixes and wondered if it was a hardware problem. It was just sitting on her desk, so it wasn't dropped or physically damaged. However, they advised to look for HP forums to see if anyone has any further suggestions, so here I am!
I am not experienced with this stuff, but I can follow directions. I was hoping someone out there would have some ideas for me to try to fix this for her. Perhaps some physical network card is broken, for instance, and could be replaced cheaper than a new laptop or professional repair.
Thanks in advance for any assistance and please let me know if you need further details.
--Gordon
Is dit een goede vraag?
1 Opmerking
It sounds like the internal Wi-Fi/Bluetooth card may have failed—try reseating or replacing it (they’re inexpensive) or using a USB Wi-Fi/Bluetooth adapter as a quick fix.
door Rashmi Kandhil
