Ga door naar hoofdinhoud
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Trackpad problems! After replacing battery.
Guys, I have the same problem. The jack is ruined because of learning by doing... I accept the mistake, but isn´t there a way to just change the controller instead of extracting my new glued in battery again to replace the trackpad that is probably working? thx for helping me out in advance
Is dit een goede vraag?
1 Opmerking
@sebastians41717 - Please make sure you have the same model as the different models often have different issues. Post a picture or two that we can see any damage.
Also, how about telling us a bit more, does the trackpad have any reaction? Did you have problems in following the guide?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
On the guide (Step 18) MacBook Pro 13" Retina-scherm begin 2015 Vervanging van de batterij the cable is somewhat fragile and if bent to much when peeling it off from the battery it may cause an issue with the traces inside, it may be worth checking this step again to ensure it is firmly connected and possibly by replacing this cable, I have had one go down on me when installing a new battery. Hope this can resolve the issue. Be sure to get the 2015 version of the cable as I believe previous editions were different.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks alot!The Cable is fine but the ZIF Dock is broken. I think I produced a short cut when I placed the battery cable on the motherboard and THEN I connected the cable... I think the procedure is to take off the battery again and change the trackpad incl. the controller board.
door
Voeg je antwoord toe
Sebastian Spiewok zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 68
