Ga door naar hoofdinhoud
De Dell Latitude D630 is een dunne en lichtgewicht versie van de Latitude-lijn. Met een 14,1-inch lcd-scherm en een 9-cellige accu is deze laptop bedoeld om mobieler te zijn.
I need password system bios
I'm trying to types password is rejecting and I'm trying to
Set up and to boot menu is all rejecting
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I am going to expand on @dinoo_fixit's answer as they missed key details. When you get the master password, it's case sensitive. On the D series and early E series machines you enter it and press Shift+Enter, then it will get you in. The key here is on Core 2 era E series machines it just gets you past the initial prompt - you need to make it permanent as if you were setting a new one. The trick is you need to go into the security menu, put the master password in the administrator password box and leave the other boxes blank - this will clear it out. Once you do that, save the changes and exit the BIOS.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thanks, this should be the accepted answer
door
It is a very old laptop, first of all disconnect/reconnect CMOS battery for an initial reset (Dell Latitude D630 CMOS-batterij vervangen) and then use a tool like this (https://bios-pw.org/) to insert serial number/asset tag and get a recovery password
Score 1
1 Opmerking:
BIOS battery hasn't worked since the C6XX series. Master password is the only way.
door
Voeg je antwoord toe
Singo Phumudzo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 334
