Ga door naar hoofdinhoud
The DualShock 2 Analog Controller first appeared with the PlayStation 2 and featured only minor cosmetic changes in screw locations etc.
all left side buttons are not working
All the buttons on the left side are not responding including the, left joystick and, the start and select buttons. I have not try'd anything yet, because I don't wan't to risk breaking them, so give me the no duh answers.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi!
Hmm, usually it's caused by the button circuit membrane. This can be fixed by replacing it.
Still, it is weird that the joystick also stopped working, then it does look like it's motherboard related.
First of all, I would replace the button circuit membrane and see how that goes. If this didn't worked, then it's most likely the motherboard..
Please let us know how it goes!
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
thank you so much I can not wait to try that
door
I just realized the joystick was working, so it must be the circuit membrane like you said.
door
Yes, then it must be that part! Replacing the circuit membrane would probably fix it!! Good luck with the repair!
door
Voeg je antwoord toe
fix it mikey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 82
