Ga door naar hoofdinhoud
How to had reset the mobile
Why is phone adaptor over heating
Is dit een goede vraag?
Score 1
3 opmerkingen:
Is it official one and is it supporting voltage that's in your country?
door
Best adaptor
door
There is a problem with 5G internet on mobile.
door
Voeg een opmerking toe
2 Antwoorden
Maybe it doesn't support the voltage in your country.
Was dit antwoord nuttig?
ALL modern chargers are 100-220V - 50-60Hz, so there isn't a country issue.
Many phones no longer come with a charger, therefore it is likely the charger you are using is under powered.
If the charger isn't rated to supply as much CURRENT as the phone wants, then it will max out at its rated CURRENT and overheat.
Voeg je antwoord toe
Arun Naik zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 56
Altijd: 392
