Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Hier vind je reparatiehandleidingen en probleemoplossingstips voor de FixHub Power Series | Slimme Soldeerbout, gelanceerd in oktober 2024.
Options for heatset inserts
Hi everyone,
I've recently started using heat-set inserts in some of my 3D print designs, but I've run into a small issue — the only soldering iron I own is the iFixit one, and unfortunately, it doesn’t currently offer a tip designed for heat-set inserts.
Has anyone had any success using any of the four standard tips for this purpose? Or is a dedicated soldering iron with a compatible insert tip the only real option?
Would love to hear your experiences or any creative workarounds you've found!
Is dit een goede vraag?
Score 2
7 opmerkingen
I forward your question to the iFixit product team.
door Deel
@danj Thanks, Dan.
I don't have a lot of experience with iFixit product team so fingers crossed we see something positive. The proprietary design for the tips is great to protect their product, but I can't help but feel like it goes against the ethos of iFixit.
door Deel
@benbrooks23043 - there is another company that uses the same cartridges as others have used them from other posts.
door Deel
Not sure on this forums view on bumps but I would love to have some feedback from anyone else about the issue.
door Deel
Hi all, just bumping again to see if anyone has had success and what tips they were using. I'm thinking the bevel 1.5 or cone would be best but I'm yet to try.
door Deel
2 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
It appears that the heat set tip has been released. I am posting it here for future reference. As of now, it is difficult to purchase these tips in Australia, so I plan to switch to a more universally supported unit; your experience with availability may vary.
https://www.ifixit.com/en-au/products/fi...
Alternatively, the part ID is IF145-881-1ip.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Ben zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 31
Altijd: 418
