Ga door naar hoofdinhoud
16” QHD+ 165Hz 16:10 Display, AMD Ryzen™ 9 7940HX, NVIDIA® GeForce RTX™ 4070, 16GB DDR5, 1TB PCIe Gen4 SSD, Wi-Fi 6, Windows 11.
How Do I Reset The Intrusion Switch?
Upon opening the device, an ambient light sensor inside will trip, and forcefully shut the device down. I can't for the life of me find a way to reliably reset this sensor, and it has made my very nice laptop into an expensive brick. I did manage to get it to boot, just once, but had to take the bottom cover off to adjust a cable to I could put the screw back in, and it tripped the sensor again. Is there a solution to this problem?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @ashleywall48429
Check in BIOS for a chassis intrusion detection setting and if there is one disable it.
Update (06/12/25)
@ashleywall48429
Try the following:
Disconnect the charger if connected and then open the laptop and disconnect the battery from the motherboard i.e. just unplug the battery cable.
Press and hold the laptop's Power button operated for a full 30 seconds and then release it.
Reconnect the battery cable to the motherboard, reassemble the laptop, connect the charger and check if it now turns on and that you can get into BIOS.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Therein lies the issue, it doesn't even respond to power when the system is tripped. I can't get it to show a power light without repeatedly taking the bottom cover off, reseating the battery, and trying again for several hours.
door
The ambient light sensor is on the USB daughter board. It seems to only be enabled when the battery is connected and is tripped when the cover is off and both battery and charger are connected. You need to drain power as suggested by jayeff and DO NOT CONNECT THE CHARGER until the back cover is on.
door
Voeg je antwoord toe
Ashley Wallace zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 412
