Intermittent flickering on internal display
Hello, I have gotten hold of a MacBook Pro 13" Early 2015 that someone abandoned, so I gave it a try.
I have no history of the device, but the device has a fair share of dents and scratches, so it has lived.
I charged the battery, but immediately after booting, it became apparent that the display has an intermittent flickering issue: for about two seconds, the display is normal, then it flickers for about two seconds, before turning normal again, ... and so on.
First I performed resets of the SMC and the PRAM, which did not improve anything. Then I wiped the SSD and performe a clean install of Monterey, but the same issue remained (throughout and after the install procedure).
Interestingly, when I connect an external display, either by Thunderbolt or HDMI, there is no flickering, and the machine works fine.
To exclude the possibility that the issue is related to a faulty connection, I opened the lid at the bottom and disconnected and reconnected the display cable a couple of times, still to no avail.
Did anyone have a similar issue? Any ideas about the root cause, or any suggestions on how to resolve this?
Is dit een goede vraag?
