Has something broken on the LCD?
While replacing a very flaked off & damaged screen rubber I noticed this
Afbeelding
There appears to be one very thin wire that is attached to it but the screen & everything is still working fine (Camera, WiFi, Bluetooth) with no 'special' effects....But, something looks broken... what is it?
Footnote: What is needed to stick down the bottom corners of the rubber behind the hinges? 3m tape does not stick to them.... The part in question appeared to have been stuck to the rubber and may have 'broken' when I removed the rubber from it.... I reallyhate these jobs :(
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
