Ga door naar hoofdinhoud
The DualShock 2 Analog Controller first appeared with the PlayStation 2 and featured only minor cosmetic changes in screw locations etc.
left analog stick is becoming increasingly squeaky
Hello,
My Dual Shock 2 is still working well after all these years! However, the left analog stick is becoming increasingly squeaky, and has begun to stick on rare occasion, but still functions near perfectly 99.9% of the time. Is there a simple trick to loosen the stick, and perhaps any buttons such as square and X, to prevent squeaking and sticking, using a household lubricant product such as WD 40?
Thank you,
Daniel McNamara
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi Daniel!
First I would try to clean everything in there.
You can just use a wet cloth and clean it (make sure that the cloth is not too wet!).
For the stick, you could use ispropryl alcohol and clean it and see if that makes a difference!
If not, then you might want to replace the stick (worst case).
Please let us know how it goes and good luck!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
D_mac08 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 123
Altijd: 529
