Ga door naar hoofdinhoud
Poco M4 Pro 4G Uitgebracht op 16 maart 2022 179,5 g, 8,1 mm dikte Android 11, MIUI 13 voor POCO 64 GB/128 GB/256 GB opslag, microSDXC
Charging problem to my phone
When I put my phone on charge it is not getting charge faster and having automatically charging on and off problem why it is happening?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Hey there!
If I had to assume, I would say that your charging port has a bad connection to its PCB. Before you open it up to look, however, make sure you try a different cord and/or a different wall outlet to make sure they aren't the problem. I would also check your settings to see if you have "prioritized charging" or something along those lines turned on. The setting could be making your phone not charge at certain points.
If you have confirmed that everything I've listed isn't what's wrong, I would either open it to see if the charging port is bad, or even take it to a local repair shop to have it looked at.
Best of luck!
Was dit antwoord nuttig?
Poco m4 pro 4g speaker was filled by dust
When I put phone on charging charging was soo slow
Voeg je antwoord toe
Bm amer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 662
