HDMI Controller Tester Questions on PS console
Hello
I replaced my HDMI Port, and all soldered connections are solid and have no bridges.
The ps5 starts up and will boot to white light and stay there.
I still don't have any picture, and monitor does receive a signal.
I've changed HDMI cables and tried a different TV.
All the components are still in place around the HDMI area.
How do I test the HDMI Controller to see if it is the problem for no picture?
Can I use a voltage tester to check the HDMI Controller chip and or components around the HDMI area?
I used an HDMI tester and showed power but no signal coming out.
Afbeelding
Thanks In Advance
Is dit een goede vraag?
Voeg een opmerking toe
