Ga door naar hoofdinhoud
De GameCube is de vierde spelconsole van Nintendo. Reparatie is eenvoudig en vereist alleen algemeen verkrijgbare reparatiewerktuigen.
3rd party Gamecube Memory Card doesn't read saves
Whenever I try to use the memory card in a game it says it's damaged, and in the settings it says: "The device inserted in Slot A cannot be used."
The only thing that happened to that memory card was me moving it from my Gamecube to my Wii occasionally.
Is dit een goede vraag?
1 Opmerking
Which model of GameCube is it? (If it has a Digital AV out, it's a DOL-001. If not, it's a DOL-101.) I'm not sure if it would make a difference, but it might. Does it still function on the Wii? That could also make a difference.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi!
Do other memory cards works fine?
I would try this first before you are going to replace the front panel.
If so, then I would replace the memory card and get rid of the broken one. It won't be easy to fix that one unfortunately...
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I did end up replacing the memory card with 2 old used official ones from eBay which are still working now a year later.
door
Glad that a new memory card did work! Have a great day :)!
door
Voeg je antwoord toe
Nirby 74 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 229
