Ga door naar hoofdinhoud
De grotere versie van Samsung's vlaggenschip, de Galaxy S8+. Uitgebracht in april 2017.
SIM card door locked
I can't open the SIM holder, it seems to be stuck; how can I remove it to take out the SIM?
I tried using a paper clip, but it doesn't click because it seems stuck.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
This one can be tricky because you dont want to force anything causing damage. Do you have access to a proper sim eject tool? I know a paper clip should and will work, however, I have had this very issue you are explaining. Worst case scenario is that you will need to remove the back and reset the sim eject pin. It's a black plastic pin near the sim tray that looks like a tiny cylinder.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Piero Sabino zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 20
Altijd: 234
