Ga door naar hoofdinhoud
Reparatiehandleidingen, ondersteuning en informatie over probleemoplossing voor de 13-inch MacBook Air uit maart 2024, met Apple's M3 SoC. Uitgebracht op 8 maart 2024 en te herkennen aan modelnummer A3113.
Screen panel closing issue
I have an mba purchased in october of the last year. I have noticed today that when I close the screen, it will not remain closed at all. Is this normal or it is an issue and I need to get Apple service?
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sounds like either the uppercase has warped a bit or the lid hinges are out of alignment.
Make sure you don’t have a snap-on shell as these have tabs to hold them on the gap between which is to narrow and all you do is crack you display. I only recommend skins which are more than enough for most.
Was dit antwoord nuttig?
Score 1
22 opmerkingen:
I didn't use a shell and since I bought it, rarely I'v closed the lid, maybe at least 6/8 times. I'm a bit worryed
door
@ziobru Do you use a Keyboard protector or one of those webcam sliders?
door
I have a keyboard protector but it's very thin, I've tried to remove it, but the problem still remain
door
@ziobru - as your system is likely still under warranty I would head over to the Apple Store to see what they can do. But leave the keyboard protector at home.
door
I purchased it on the mediaworld online store and not into an Apple store. I don’t know if Apple will give me support directly. I sended today a mail to the support of the online store to understand if I can get warranty from them or I will need to go to an Apple store
door
17 commentaren meer tonen
Voeg je antwoord toe
B1P zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 382
