Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Verschenen in oktober 2008 / 2,4, 2,53, 2,66, 2,8 of 2,93 GHz Core 2 Duo-processor
Can I replace just the keyboard?
My MBPro A1286 Intel Core Duo Model 5,1 got wet last weekend. Now several keys don't work. I did some research and found out that most parts providers offer only replacing the top case along with the keyboard. (pretty expensive!) Then I found this site Link text that offers Just the keyboard (much better, money-wise) Seems to good to be true...Is this doable? and how come you don't have a guide here for this procedure? (did a search with my model number and the closest I got was to a top case replacement guide) Thank you!
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
hi , yes its totally possible to change only the keyboard but its much difficult and take many time.
No guide on internet for replace only keyboard if i have time next week i will make a guide for you
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Yes, you can replace just the keyboard.
You can use this guide as an example:
Replacing keyboard on MacBook Pro 15" (Mid 2010)
The guide is for a different model but should be very similar.
Afbeelding
Score 2
Voeg je antwoord toe
gilarturo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 3,804
