compatible parts/logicboard and HDD.
This is just to confirm what I think to be true but if anyone knows different...I bought a 5th gen(video) ipod as a bit of a break. It apparently didn't power on. Someone had been in there before me..So I pull it apart, reinsert battery cable and LCD/HDD and it powers on but no backlight on LCD. I couldn't get to the diagnostic mode but it would go into disk mode but then would not restore in itunes error 1434. The HDD never made sad and dying noises so I was a little confuddled. Tried erasing the HDD using disk utilities but got a "posix" error.After a small mishap with the LCD retaining flap I have pulled everything apart and looked at the part numbers. It would seem that the logicboard is for a 6th generation ipod classic. Now then, if everything else in this ipod is for the 5th gen (ie back/headphone/battery/LCD and HDD cable) and yet it seems to power/charge and be recognised in itunes is there
1) a way to use this board and somehow upgrade/update the HDD I have,( have seen OT03 answers about zip to USB adapters for other generation ipods but am not sure what I've seen for sale over here is what he has referred to? or whether this is simply something I can sort with a HDD flex for a 6th gen?)
2) should I just replace the logicboard with the correct one and create a new 6th gen?(I think option 2 is a bit expensive...?)
I guess also I'm asking which gen (5 or 6) would be the better one to go with.
Update
this is what I bought/thought was a 5th gen ipod..
Is dit een goede vraag?
6 opmerkingen
anyone know if there is any difference between all the dock connections? I know there are 19 and 30 pin, but I'm not finding anything for the 5G video but can find plenty for the 2G or 4G touch. As they all run off the same USB connection I'm thinking I can adapt this to fit the 5G...don't currently have any of these in the repair box to compare at present. Soldering isn't the problem but pin arrangement would be..
door pollytintop
pollytintop, thank you for accepting my answer. The dock connectors are available , but pricey. Check on here http://www.ipodjuice.com/5th-gen-ipod-ch... It is actually cheaper to get a new logic board. I have a price request in to these fine people, but have not yet heard back http://www.lunacommerce.com/57-ipod-vide...
Most of the difference is the height from the logic board to the pin blade, which is needed due to the different depth of the different iPod models. The pinout has pretty much remained the same up the 4th gen touch.
door oldturkey03
I'm going to pull apart an old iphone 3G dock..I just need the plastic pin part really that the USB connects onto. It's going to be a bit of a bodge job I think but there should be a way out of this without buying the logicboard? If I can keep the old housing and put the new pin plate in then it should work. I'll let you know what happens...could be an absolute disaster!
door pollytintop
bah humbug! tried to clip metal cover off dock pins-success. Next part went all very wrong...new logicboard it is then.
door pollytintop
Sorry to hear that, nice try :-) How much will a new logicboard be with your VAT on it?
door oldturkey03
1 commentaar meer tonen
