Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Nokia 5130 XpressMusic is een van Nokia's mobiele telefoons in de XpressMusic-serie. De telefoon werd uitgebracht in januari 2009 en de productie werd gestaakt in 2011.
remove the memory card password
I forget memory card password please help me
Is dit een goede vraag?
Score 18
Voeg een opmerking toe
17 Antwoorden
Filteren op:
Het nuttigste antwoord
Sreenu, try this "
Go to file manager on your phone
Go to settings and choose system folders,
In the System folder, find a file called mmcstore
Send the file to your PC using IR/Bluetooth
Open the file in Notepad
The password you need for your memory card is located within that file"
The other thing that might work for you is to "
1. Insert your card into your phone, without accessing it through the phone
2. Run FExplorer and Open the path C:\system
3. Find the file called mmcstore, and rename it mmcstore.txt
4. Copy that file (mmcstore.txt) to your PC and open it in Notepad
5. Your password will be located within that file. From here
One more thing you could try is to use a memory card read for your computer and format the cared through that. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
there is nothing with the name of File manager or application manager in Nokia 5130
door Deel
Score 3
i forgot my memory card password please help me remove
Score 3
yes
Score 3
nokia c5130 memory card not opned
Score 1
how remove the forget passowrd
Update
how to remove the forget password of memory card
Update
tell me hoe remove password
Score 1
how remove the password of memory cad forget
Score 1
i forgot my memoey card password please help me remove
Score 1
to know the password
Score 1
hellp
Score 1
i didnt know about system folder in my phone
Score 1
Forget memory card password
Score 1
how to unlock my password
Score 1
Hello., i've tried this for my Vivaz U5i sony ericsson. use thirdparty file managers like Xplore or others that has an option to show you hidden files. then follow the steps of @oldturkey03 . never update Xplore because i can't see again mmcstore file after update. now i got 2 mmory cards cannot be used bcoz of password. my Vivaz has now a broken resistive touch. but anyways goodluck guys :)
Yes I forget my memory password
memory card password unlock
Update (09/12/2017)
my memory card password unlock
Remove tha memory card password
Voeg je antwoord toe
Sreenu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 35
Altijd: 32,434
