Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Flickering screen when powered on
How to stop a flickering screen?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Have you tried HP web site:
Why is my laptop screen flickering?
Several factors can cause your laptop screen to flicker:
1. Incompatible applications
Some applications may conflict with your system’s display settings, causing screen flickering. To determine if this is the case:
  1. Open Task Manager (Ctrl + Alt + Del)
  2. Observe if the flickering continues while Task Manager is open
  3. If everything except Task Manager flickers, an incompatible app is likely the culprit
2. Outdated display drivers
Outdated or corrupted display drivers are a common cause of screen flickering. Keeping your driver software up-to-date is crucial for optimal performance.
3. Loose or damaged internal connections
Physical damage or loose internal connections can cause screen flickering, especially if the issue occurs when you move your laptop screen. Examining the display cable can help determine if it needs to be replaced or serviced.
4. Refresh rate issues
An incorrect ++refresh rate++ setting, particularly when using an external ++monitor++, can cause what appears to be screen flickering.
5. Hardware problems
In some cases, hardware issues such as a failing ++graphics card++ or damaged screen can cause flickering. Additionally, a failing graphics driver can also cause flickering and should be checked.
Was dit antwoord nuttig?
Voeg je antwoord toe
wheals chanda zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 19
Altijd: 232
