Xbox v1.6 PSU odd behaviour.
I am currently working on an Xbox v1.6 with a 240V Delta PSU. The unit wouldn't power on, when I opened it up the usual 3300uf 6.3V caps were bulging and leaking, luckily nothing had gotten onto the board yet. I tested the PSU and it gave steady 5v reading on all orange wires while plugged into the board.
After changing the leaking caps for new ones and connecting everything back up it didn't turn on. The weird thing is that now when the PSU is plugged into the mobo it gives no readings however when it is unplugged from the board it gives all the correct readings.
I haven't done anything to the PSU and have no idea why it would be behaving this way, when I know it was definitely giving correct readings while connected to the board before changing the caps.
Does anyone have any ideas/suggestions that could potentially lead to a solution here? Any help is appreciated
Cheers
Levi
Is dit een goede vraag?
