Ga door naar hoofdinhoud
Model k52t38 (ook bekend als de Lenovo Vibe K5 Note)—een Android-smartphone met een 5,5-inch scherm, voor het eerst uitgebracht in 2016. Beschikbaar in Champagne Gold en Platinum Silver.
phone switch off not starting
not able to start the phone when connecting to charger only red light comes but does not starts
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
If you see a red light when connecting your phone to the charger but it doesn’t start up, it suggests that the phone is receiving power, but it might not be able to boot up properly.
If the phone has a hardware issue with the battery or the internal power supply, it could cause the phone to not start even when charging. The red light may be an indicator of this issue.
In this case, charge for at least 30 minutes to an hour before attempting to power it on. Sometimes, if the battery is deeply drained, it might take a while for the phone to show any signs of life. Ensure you're using a reliable charger.
Was dit antwoord nuttig?
2 opmerkingen:
i charged the phone and also i removed the battery and added new battery to it but than also not starting what will be the issue in hardware i am technical guy would you recommend me the schedule
additionally i remove the battery and i connect the charger without battery also than also red light was coming but the phone was not starting
door
@rahulyadav37502 If the light stays on even with the battery in and no boot, the issue might not be the battery itself. A failed motherboard, damaged power button, or blown fuse (common in older phones after battery issues) could be at play.
door
Voeg je antwoord toe
Rahul Yadav zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 30
Altijd: 267
